Looking for Amplifier for working with my Flex 6300: suggestions are welcome!
What are the drive requirements of your 811 amplifier? Do you suppose you inadvertently over drove it? There has been a recent thread of having Flex set the power to lower values as a default. Several have complained that it defaults to 100 Watts and that might have been your problem. You might end up with the same problem with any other amplifier that requires less drive.
Jim, K6QE
Looks like it requires 100 watts in:
http://www.dxengineering.com/parts/ame-al-811
Interesting read about the 811-A:
http://www.arrl.org/files/file/protected/Group/Members/Technology/tis/info/pdf/9604051.pdf
k3Tim0 -
To tell the truth I guess it was that happened....I have had used for a year with my kenwood 480SAT with No problem....I connected to my flex today was chasing an AO150 (Spain 150years IARU)...and changed band to 17mts...and did not check RF power.....it will be good "default" to 10 watts.....Now 'm looking new amplifier :-/0
It requires 70 watts......could go to 100...but its not recommendable by manufacturer 0
I use an Elecraft KPA500 and matching KAT500 tuner with my 6300 and they work fine. It is the 2nd picture on my QRZ page: http://www.qrz.com/lookup/kq1q3
I sold my TL-922A and ALS600 and am now running the ACOM 1000 with my 6300 one year now. VERY happy I did.
I have tune power set to 20watts and power out set to around 60 watts in each band profile otherwise the amp' s micro complains of overdriving when I tune. The Acom 1K will run 1200 watts but shines at 1000 watts all day any band any mode 6-160. 1K on RTTY is nice! Also will tune up to 3:1 SWR. Would do it again, price point is right for me any way. Solid amp!1 -
I second the Elecraft KPA500 amp and KAT500 tuner. It will literally turn your 6300 into a 500-watt transceiver. Changing bands is effortless.
Or, you could repair it? do the tube filaments light up? Is there any B+ (high voltage) ? A new transformer is not that expensive..
JM2C...73
Tubes looked OK...but something went wrong an spark burned meters lights and led light turn off...i will send to repair...but don't wanna expose my flex on risk connecting it.0
What amp can handle AM? I have a TL-922 but no WARC bands.1
I use a Yaesu Quadra. It works seamlessly and gives a solid 1K.
If I were looking today I would probably look hard at the Expert 1.3K-FA.
Jon...kf2e
Can they handle the duty cycle of AM?0
When you get the 811 amp repaired, please let the group know what went wrong and the probable cause.
Jim
The Quadra manual says it can do 500 watts continuous for 1 hour. It doesn't specifically mention AM.
Generally speaking, a linear is capable of approximately 1/4 continuous power of a SSB linear. Also remember that the peak power of an AM signal is 4 times the average carrier signal for 100 percent modulation.
Jim
I use both a Heathkit SB-200 and an SB-220 (not together obviously) with great results.1
The KPA500 manual says 500 watts key down for 10 min, followed by 5 min stand by, etc. For most applications that would work, but it might cramp the style for AMers to restrict a single transmission to only 10 minutes
Of course if they could fit within 10 min they'd have plenty of time to cool down before the next transmission. 0 -
Key down with continuous carrier does not imply you can run 500 Watts on AM. For 100 percent modulation a carrier of 500 Watts key down would have to be able to run 2000 Watts peak power. If the amplifier was rated at 500 Watts was modulated at 100 percent there would be distortion. One has to keep the power to approximately 1/4 the rated key down power to avoid this distortion.
Jim
I am not an AMer that goes more than 10 minutes. I currently also have an IC2KL I run at 100 watts on AM but the fan sounds like a jet taking off1
Just to be clear, as Jim said due to the 4:1 ratio between AM PEP and carrier power, the unmodulated max key down for the KPA500 in AM might be about 125 watts. In AM you'd still be getting 500 watts on a fully modulated signal. Due to the intermittent nature of that modulation, I'd expect the KPA500 could continue an AM phone transmission for quite a while -- certainly longer than 10 min. although I haven't see any spec.1
I bet at 2 minutes a fan would come on that sounds like a jet1
If I had to start from scratch, I'd consider:
http://www.w6pql.com/1_kw_sspa_for_1_8-54_mhz.htm
73, w5xz, dan
Wow! Joe!! Amazing Pictures.....I saw you're photographer too!...picture from your Flex, KPA500 and KAT500 is Awesome!!
I will take a look to Elecraft-..... Thanks for your suggestion....
George
YV5WZ
http://www.qrz.com/db/YV5WZ
It's amazing you are still alive after looking at the first picture,1
The Acom 1000 won't work on 120v?1
Yes, driving them at 100 Watts when they only need 70 is why I see so many really wide signals on the bands...
Accidents happen, as in your case, bu some folks do it on purpose because their meters say they are getting out better. By the way, I hear good things about the ACom 1010, it is relatively forgiving, easy to tune, tolerates up to 3:1 SWR. I wish I had one. Maybe someday....0 -
Lol, Burt! We have all let reason and safety go out the window a time or two when we were young and excited (read that foolish!) I managed to get my hand across the plate cap of a 2e26 tube, about 600 volts, when I was 16 years old. I have been living on borrowed time for the past 40 years. BTW, I ALWAYS double check the power supply twice before working on equipment, even with 12 volts!0
@Joe, that is precisely my environment with my 6500.
We share very similar interests, I got emComm certified via the ARRL courses, and hold a commercial multi-engine license. I am very impressed with the 3D storm images...really nice!0 -
So....Radio Ham Amateurs....Photography. ...and Aircraft Pilots....let's add motorcycles ...
I sold my Honda 350 to a cop in Reston, VA in 1979. I think that was the last time I was on one. However, it wasn't the last time I thought about buying another.
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 141 Contesting
- 985 Third-Party Software
