Heil Sound PR 40 Equalization
YV5WZ
YV5WZ Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
While I´m waiting for cable CC-1-XLR-Y-BAL arrives  to connect  my Heil Sound PR40 to Flex 6300, I wonder if anyone knows: PR40 Equalization  profile exists anywhere?
George
YV5WZ
  • Lee - N2LEE
    Lee - N2LEE Member ✭✭
    edited February 2017
    I use the PR-40 and I think its personal and you have to create a profile to match your voice.
    The PR-40 does have quite a bit of low end so you might have to compensate for it.
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    Default HM-Pro seems to do a good job for my PR40
  • Norm - W7CK
    Norm - W7CK Member ✭✭
    On my 6700 I have to have 2 different profiles.  One for SSB and another for FM. Here's a place to start.
    2 different ones for SSB you can use as a starting point.
    SSB1: 0, 0, -4, 4, 5, 6, 6, 0
    SSB2: -8, -7, -5, -3, 2, 7, 8, 0
    FM: 5, 8, -1, 6, 7, 8, 8, 0
    If you find a setting that you really like and you get good reports over the air, PLEASE POST THEM.
  • George KF2T
    edited December 2016
    Good point on the FM profile. It is worth having.
  • Stewart, GM0GTU
    George, The 6300 doesn't have a balanced mic. i/p, so will the CC-1-XLR-Y-BAL cable work?
    Stewart GM0GTU
  • YV5WZ
    YV5WZ Member ✭✭
    Thanks Steward  for your reply to my question
    One Thing I watch closely when I bought a product is customer service...and FlexRadio Customer Service is the best...I haven't  met Tim Ellison, but he's amazing Customer Experience Manager.....Here is the answer to my question I sent to him directly:
    "We made a grounding change to the internal mic circuit on the FLEX-6300 earlier this year that makes the input essentially balanced.  The ACC-CC1XLRY-BAL is the correct mic cable for the FLEX-6300 and the PR40 or PR781. "
    Thanks Tim!!
  • YV5WZ
    YV5WZ Member ✭✭
    Thanks Norm (N2LEE)......I apologize for my late reply to you (lot of work)...Thanks for share with me and community  your profiles for Heil PR40, I will create SSB today (both) to test, and I promise I will do the same with FM profile...as soon as I could upgrade to 6700 hehehe :)   Thanks ...hope catch you on bands!
  • George KF2T
    I'm sure a good balanced to unbalanced adapter will do the trick nicely.
  • Stewart, GM0GTU
    edited May 2015
    All, I ordered an equivalent cable to the Heil one, that is made in the UK using quality components, but half the price. Thanks for the guidance.
  • Norm - W7CK
    Only if you use FM.  If you do use FM and you don't have a separate profile, it will sound absolutely terrible.
