I've read FreeDV destabilize Flex Radio using SSDr 1.4.3? is it true?
YV5WZ
Thinking to install DVfree, running Windows 8.1
Haven't tried it with 1.4.3, but, it does work with 1.4.11 (the latest version of SSDR). Only issue I've had so far is common to digital transmissions, weak signals just go away or break up and start to sound bad. But, when signal strengths are good, it works well.
james
If my 6500 moved an inch I could see marks in the dust. Nope. Still stable after FDV was used.1
Thanks James for your reply....I'm still using Smart SDr 1.4.3.132 I'm a bit concern about comments about 1.4.11 I will take this chance to ask you about it: did you have any trouble installing new 1.4.11?0
Great!!....Thanks Steve!...
hahahaha....I'm same way! :-D No one may a enter to my radio room, my home rule hahahaha0 -
No, I did not encounter any problems with installation. And so far, everything seems to work fine. And there is a very noticeable improvement in NR and ANF. I cannot test the Noise Blanker as my location is very quiet, so I cannot comment on that.
Installation is same as previous versions. Hope that helps and I hope you have no issues.
james
No problem loading 1.4.11 here either on 3 computers, 2 running Windows 10 and a 7" tablet running windows 8.1.
Cheers
Paul
gi4fzd1 -
Thanks James!...I took your advise ...(thumb up)0
Thank you GI4FZD
Great info!0 -
I had heard there is a rare bug that causes the radio to become unresponsive while in the FDV mode. Emphasis on rare, but enough to keep FDV out of the official release for now.0
I have had the RARE radio lock up will in FDV mode. Required a hard reset ( remove DC for a few minutes) to recover the radio. You may or may not run into this problem.. If you do run into the problem, just stop using FDV and wait for a fix.. In any case, no damage is done to the radio.
AL, K0VM
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
