A DAX question regarding slices
Ross Biggar
Ross Biggar Member ✭✭
edited February 2019 in SmartSDR for Windows
I have been using DAX channel 1 on all my slices, can I use say channel 2  on slice B and DAX channel 3 on slice C etc?
I assume I also have to change where the audio and TX is looking in the software running on that particular slice
Is this correct
Regards
Ross ZL1WN
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited November 2016
    I don't see anything wrong with that Ross. Say you were working digital split. You'd pretty much have to do that, right?
    Walt - kz1f
  • George KF2T
    George KF2T Member ✭✭✭
    Yep, that's the whole idea. Set your levels and such for each application using a unique slice for each. Makes life easy.
