A DAX question regarding slices
Ross Biggar
I have been using DAX channel 1 on all my slices, can I use say channel 2 on slice B and DAX channel 3 on slice C etc?
I assume I also have to change where the audio and TX is looking in the software running on that particular slice
Is this correct
Regards
Ross ZL1WN
Is this correct
Regards
Ross ZL1WN
I don't see anything wrong with that Ross. Say you were working digital split. You'd pretty much have to do that, right?
Walt - kz1f
Yep, that's the whole idea. Set your levels and such for each application using a unique slice for each. Makes life easy.0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
