SmartSDR 1.4.11 Persistence
Anthony Bowyer
I've ran across what might be a bug in 1.4.11. I use N1MM+ and typically change bands from it rather than in SmartSDR.
While testing NR I noticed if it was on, and I changed bands or modes within the same band, then came back, the setting was not restored, and the level was set back to 0, if this change was initiated from N1MM, but it was persistent if the change was made in SmartSDR.
In case, I cleared the persistence db and the issue changed, so that the NR setting is not persistent either way.
I'm pretty sure it was persistent before with band change from either N1MM or SmartSDR.
It is odd that it was persistent with band change in SmartSDR, then I cleared the db and this was no longer the case.
Maybe something to look into?
Anthony/NT4X
I saw this behavior in 1.4.3 but I don't use N1MM. It seems that the NR was persistent for 80M but I can't get 40M NR to be persistent (or any other band), and I saw the same behavior in 1.4.3 and now in 1.4.11. Just my input that it is being, and has been seen before by another user. Greg, N8GD0
Good to know it's not my mind (or lack thereof) playing tricks on me!0
A further observation: the NB does seem to be persistent with band change if SSDR is used, but not via CAT. NR neither.1
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
