Memory Function Question
edited March 2018 in SmartSDR for Windows
When I create a memory with the Noise Reduction on, I find that when I go to another memory on a different band and then go back to the original memory the NR is off. Does the memory function not save the NR and all the profile for that band when it is set. Am I doing something wrong? Any advise would be appreciated.
Welcome!
  • Member ✭✭
    edited January 2017
    Alan,
    Open the memory form in SmartSDR client.  Open the memory window & look at the headings.  They are the only values saved in the memory object in SmartSDR.
    73, Ray, K9DUR
  • Member ✭✭✭
    edited February 2018
    I think it is by design not to save NR settings. NR is selected as needed band by band.
  • Member ✭✭
    edited March 2018
    Also NR, ANF, and  NB will change with daily band  conditions. Today it's like someone turned on a Monster NR on all bands...
