Does FreeDV work on 2 meters?
Cal  N3CAL
Cal N3CAL Member ✭✭
edited February 2017 in FLEX-6000 Signature Series
Now that I have FreeDV installed and running on my Flex-6300 on HF,   I'm curious if FDV will also work on the 2 meter band?  I have an Elecraft XV-144 transverter and notice the FDV mode is available when I select the XVTR band.  Just curious if FRS has done any testing to confirm or deny it works on 2 meters?
  • K6OZY
    K6OZY Member ✭✭✭
    Yes. It works fine on 2M. I'm using a DEMI 75W 2M amp on my 6700.
  • pa0bie
    pa0bie Member
    edited May 2015
    It works fine for me to.
