Closing a conversation
Ross Biggar
Ross Biggar Member ✭✭
edited January 2017 in FLEX-6000 Signature Series
I had a problem with WSJTX and the 6500, I thought I had solved it, a couple of hours ago, by going to the TS480, and I put a message to that effect on this system. However after 2 contacts WSJTX and the 6500 refused to work together and I posted a note to that effect.
I now see that the conversation has been closed by someone.
Frankly that is no help at all.
So for WSJTX I have gone back to my Elecraft K3 and My Tentec Orion II both of which work perfectly, with no problems on WSJT. Also I should add that Elecraft go to a lot of trouble to help people with problems.
Ross  ZL1WN
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    Ross
    It was pretty obviously closed because you said that your problem had been solved.  I would suggest that you got pretty good support via this Community in that the problem was solved once before for you
    Now you seem to have an issue again with WSJT
    Could you please describe your latest problem in Detail
    Or rather it would elicit more responses if this Conversation were closed and you could pose your issue in a new conversation with a more appropriate and more descriptive title..
