audio recorder
K2CB Eric Dobrowansky
Will there be any enhancements to the audio recording functionality in V1.4 or V1.5? I have not seen anything mentioned about it lately. Awhile back we were led to believe it was coming shortly, and the simple recorder was just to get by for the time being.
Is the delay due to the need to get audio in and out of the PC via the LAN connection? If this is the case, does this mean we can expect it along with the audio over LAN mentioned for the next release?
4
Hi Eric,
I hope they add the "black box" feature when it does make the road map. The "black box" idea only has 8 votes so far but I think it would be very useful. Here is a link if you agree and woud like to add your vote.
https://community.flexradio.com/flexradio/topics/black_box_recording_add_a_looping_option_to_the_rec...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
??????0
Hi Eric,
I probably wasn't clear but this comment below is from the Black Box idea and is basically the same question you were asking. I doubt we'll get any FRS feedback so will just have to wait and see.
Given that LAN Remote will pass the audio over to the PC. --- Does that make it easier to support both the "black box" feature as well as providing a method to write the files to the local PC?
Regards, Al / NN4ZZ
Any chance that an enhanced recorder will make it into V1.4 or 1.5? I'm sure a lot of folks are looking forward to having a functional equivalent of the previous generation, if not better. At a minimum, a simple way to archive the recordings would be nice.0
Any chance the full recording functionality will make one of the next few releases?0
In the mean time, you can send audio out a DAX channel to Audacity and record great sound. You can then edit and export to a number of different formats. Audacity is one of the most popular free audio programs on the net. At least the best one I have found.
Ken - NM9P1 -
Still no improvement to the recording functionality in V1.5?0
- 323 Community Topics
- 578 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
