Michael VK3MM. Controlled Envelope SSB
Mike McDonald
I wonder if Flex has considered implementing Controlled Envelope SSB in the flex 6700?
I read they done some development work in this area in the past and as it seems to be largely a software thing I thought it would make a good addition?
2
I "know" CE-SSB is in there...
Checking the previous release notes from V 1.2.17., I believe it is called Downward EXPander (DEXP). :
http://www.flexradio.com/downloads/smartsdr_v1-2-17_release_notes-pdf/
The release note has some important information about setting mic-gain levels that are relevant in the current s/w. It is a must read.
The QEX article also eludes to it being in SSDR:
http://www.arrl.org/files/file/QEX_Next_Issue/2014/Nov-Dec_2014/Hershberger_QEX_11_14.pdf
CE-SSB is different from Envelope Tracking that sets the PA voltage to a setting for maximum efficiency based on the instantaneous power. The interested student will Google "Envelope Tracking" for further details.
Best Regards,
k3Tim
The CE-SSB speech processor has been in SmartSDR for several versions. It is the PROC feature.0
CESSB was in SSDR long before the QEX article0
Thanks for the response I will check it out.
Cheers
Michael VK3MM
Thanks for the link to the article Tim....0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
