I think my 6500 just died
Burch - K4QXX
Burch - K4QXX Member ✭✭
edited July 2018 in FLEX-6000 Signature Series
I was listening on 40 meters on my 6500 this afternoon and all of a sudden I got a horrible screeching noise through my speakers.  The panadapter was frozen and then I got a message that the radio had lost connection.  I have powered the radio off (turning off the power supply to the radio) and waited a few minutes and when I turn it back on it stays on the calibrating screen for a long time and then the power button blinks red and the display says "timeout".  Not sure what to do at this point.  How do you do a reset?
  • SteveM
    SteveM Member
    edited January 2017
    Ick! Bad time for this to happen to you (Friday afternoon). Here is a link to a similar problem. Make sure you expand the replies so you can read them.
    https://community.flexradio.com/flexradio/topics/radio_failure?topic-reply-list%5Bsettings%5D%5Bfilt...
  • Burch - K4QXX
    edited July 2018
    Not sure if this means anything but when I get the timeout message the red light blinks 3 times.
  • SteveM
    SteveM Member
    edited December 2015
    That was specifically mentioned in the link I provided.
  • Burch - K4QXX
    edited May 2016
    Says it's a boot failure.  I have tried resetting it twice but no go.
  • SteveM
    SteveM Member
    Did you perform the factory reset (power down, hold OK button then power button, release)? Bruce, from the other thread, stated he had to do it many times. Also, Flex recommends you open a HelpDesk ticket for this problem.
  • Tim - W4TME
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • Burch - K4QXX
    edited May 2016
    I have reset it 4 or 5 times and no go.
