downgrading restores sensativity
M Evans
last week I posted that since I upgraded to 1.4.3 I seemed to have lost receiver sensitivity . today I actually downgraded to 1.3.8 and have had everything return to normal. Anyone else seen this problem? Any ideas or suggestions? I've already reset several times.
Michael Evans
K7URA
Michael Evans
K7URA
Have you adjusted the sliders after upgrading to 1.4.3? The scales are somewhat different between versions, which may appear to change sensitivity, etc.0
Actually I recommend that you do a factory reset and a cold boot of the radio after upgrading to v1.4.3 I suspect you have a setting saved that is not compatible with all of the extensive code re-factoring we did for SmartSDR v1.4.0. If you have created profiles, you will want to export them before the factory reset. When importing them back in, do not select Preferences, as that will probably replace the settings that may be causing your issue.0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
