Noise Reduction & ANF version 1.4.3
I have both a 5000 and 6500. I find the noise blanker on the 6500 next to worthless. The 5000 is very good in that I can adjust its parameters.
Jim, K6QE
You may have to do a reset on the rig but really the NR and Auto Notch are worse than useless anyway.0
Somebody, ought to inject that they weren't designed to be useless intentionally and are likely part of the upcoming 1.5 improvements.0
Heard that before.0
Makes me wonder if the Beta testers are on a **** break.0
Depends on the mode of operation. Under CW / SSB, the ANF / APF and NR are accessable other modes, one can move the control to 100%, select the filter and the s/w will turn it off and set the control to 0. Obviously by design but not sure why.
My Regards,
Tim1 -
Deja Vu all over again...
IIRC ... Gerald has just recently commented on the planned deliverables.
Didn't know the 6700 had a worthless NB and NR until I set it up when it was brand new. When you purchase a radio as expensive as the 6700, you do have an expectation to have a NB and NR that will rival the best of the expensive tranceivers on the market. Unfortunately, the many assets of the 6000 series radios are darkened by the lack of this hugely important function. Although, there is nothing a user can do but wait until 1.5 or a later release, it seems a shame that we will have to pay for that. It's not so much the expense of 1.5 but the disappointment in Flex in this matter.
What are we going to pay for?0
Thanks Tim! Thats the answer.... need to be in the CW/SSB modes before NR and NB function. I happened to be in the AM mode.
Gary
It's my understanding that updates beyond 1.4### will be part of the payment tier.
No, the pay releases are 2.0 and over.
They are working right now on the noise mitigation, there are to be small point releases till 1.5
1.5 should complete noise mitigation.0 -
It is my understanding that there will be no additional payments in all the 1.**** updates. There will be additional fees at 2.0 and above. Also it is my understanding if we call 1.**** a tier, 2.**** a tier, etc. no additional payments will be in each tier.
Jim, K6QE.
Thanks, I stand corrected.
Also, if you elect to bypass 2.**** and elect to purchase 3.****, there will be only the charge for the 3.**** tier.
Jim
Jim is correct.0
Bill's info is correct. We are actively working on noise mitigation and there is no cost for ANY of the 1.x software versions.0
We are aware of the deficiencies related to the noise mitigation algorithms in the current 1.4.3 version of SmartSDR and we have stated publicly that our focus for SmartSDR v1.5 is improving noise mitigation.2
One must appreciate the POWER of the Field Programmable Gate Array. In my opinion it is a paradigm from a microprocessor and related software/firmware. One can create virtually any electronic component including a microprocessor. It is not easy shifting into this paradigm. It requires hours of creativity to synthesize all of these hardware functions with firmware. I congratulate Flex of taking this route and in the end, it will pay off enormously. Please be patient. They have made wonderful strides and will continue to do so.
Jim, K6QE
Really looking forward better NB, NR, ANF. I have had my 6500 since June of 14. They have been my biggest disappointment.1
I have owned many rigs including the Icom 7800. I have yet to use a noise reduction unit I thought was worth anything. To me all they do is lower the noise to a very low bass rumble and terribly distort the audio. I some times wonder if it is possible at the this time to make a really good noise reduction unit. I am sure there are those who will disagree with me.
Jim, K6QE
I agree. NR is pretty useless for cw. Audio peaking does more for me but IMHO it needs to be done after the sidetone. None are.0
if you hold your nose just right, and get AGC-t exactly right, and turn NB on and off several times, sometimes NB works on s-7 line noise...
JM2c..0 -
For me, most noise is from arcing A/C power lines. I have tried working with the power company, but it seems their knowledge of noise, directivity, leakage, etc.. lies somewhere between an unborn fetus and a demented ape. From what I have observed regarding power line noise, most of it sounds pretty much the same. It would seem that based on the "regularity" of this type of noise special algorithms could be devised for this particular type of noise rather than just random noise. The best results I have ever achieved with power line noise is my MFJ noise canceler than uses two separate samples of the noise and by adjusting both the phase and amplitude, it is possible to almost completely eliminate this noise. I have often wondered if the same would be possible with software/firmware.
Jim, K6QE
Certainly. That should be easy. Just create an adjustable phase delay on the second receiver input for the "sense" antenna. Computers are good at delaying anyway!0
Seems the Flex 6700 would be "made in heaven" using this approach to eliminate this type of noise.
Jim
Seems one option would be to sample a different frequency with a wide and receiver even on the same antenna, and detect the impulses and use them to blank the target slice receiver. R.L. Drake did that decades ago.0
Good idea, this approach might be amenable to the 6300 and 6500. Flex has mentioned new approaches to the noise problem and maybe this technique is under their microscope.0
- 342 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 965 Third-Party Software
