SmartSDR API - display pan Status Packet get unexpected value id
IW7DMH, Enzo
Hello,
using my controller I got the unexpected id (I suppose it is so) for a phantomatic pan object as marked in the picture below.
I was aware that Pan ID start from 0x40000000 and so on, while Waterfall ID start from 0x42000000 and so on. It seems here that also Pan objects can have the 0x4200... id.
Is this correct?
This is anyway a strange behaviour because when it happens I have only one active panadaptor and it happens only when the band is changed from an external software (in my case it is Log4Om). If I change band using SSDR GUI the (wrong) status packet isn't send from the rig.
As Log4OM is using the CAT protocol I suppose it is a specific issue of the CAT APIs as using SSDR GUI everything works properly.
73' Enzo
iw7dmh
Is this correct?
73' Enzo
iw7dmh
Good find. This is a bug in the code. I have entered a fix and submitted it for review. (#1963)0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
