Flex 6500 freezing up for about 15 seconds.
Flex 6500 freezes for about 15 seconds. It stops the sound also. I am running the radio connected to the computer. Computer is laptop running windows 7 home premium 64 bit. This problem started yesterday and froze for 5 to 10 seconds. Now it freezes for 15 plus seconds. It seems to work OK for some time and then starts the freezing. I thought that maybe it was because the radio was running hot but that is not the problem. I am using HRD for logbook and digital modes. I am having problems with HRD keeping up with the frequency and DM-780 seems to also have the problem keeping up with the changes. I am only using just the HRD and logbook when it does the freezing.
Welcome!
  • Member ✭✭
    edited September 2018
    Did you try it with a different computer?
  • Member ✭✭✭
    edited May 2018
    Mike - this is a known problem, and is on Flex's bug tracker.   In the meantime, what has helped me a lot (also a 6500) is to go to the DAX control panel and disable any DAX channel you're not actively using.  While this won't help while you're operating digital modes, for SSB and CW it has stopped the problem for me.  This is just a workaround until Flex gets the bug swatted.   There's a fairly long thread  where you can go to find more information here:  https://community.flexradio.com/flexradio/topics/flex-6300-locks-out-for-a-few-seconds
       73, Duane
  • Member ✭✭
    Wonder why I have never seen this problem with three separate computers running windows 7?
    Sure is strange.
    Jim, K6QE
  • Member ✭✭✭
    edited May 2018
    Don't know, Jim.  It doesn't affect everyone, but some of us really see it big time.  Mine was locking up for the 10-15 seconds very regularly until I followed the suggestion to disable unused DAX channels (only one, in my case).   Some folks don't see it at all, some do.  With 1.4 and 1.4.3 I have it big time.  Also have the "stuttering" (black lines through the waterfall, and network quality dropping to zero) when I connect through the Wifi link - something that worked just fine until 1.4.  No problems if the PC is cabled to the router.   I'm sure the Flex guys will get this all sorted out.  I'm running Win 7 64 bit on an ASUS AMD 8-processor machine.
  • Member
    edited April 2015
    I don't have another computer to try it on. Once it starts freezing up I have to turn it off and remove power to it and shut down the software. If not done the radio is completely useless to me because it will start freezing in shorter time. I have disabled the DAX channels and that doesn't help.
  • Member ✭✭
    It would be interesting to see if there is anything in common with all of the complaints of this freezing like using third party software along with Smart SDR. There must be some kind of weird corruption going on somewhere but some seem to remain immune. Hope they find it.
    Jim
  • Member ✭✭✭
    edited December 2016
    If you haven't already, you might want to open a Help Desk trouble report.
  • Member ✭✭
    edited January 2018
    With the problem of HRD keeping up with the frequency of the radio, that sounds like the laptop CPU is heavily loaded.  What is the configuration of the laptop?  As Duane said some users are having problems with intermittent freezes for a few seconds..  I had them occur one evening, never before and never after so it is hard to pinpoint the cause..  Jim
  • Member ✭✭
    edited April 2015
    I had these same issues and symptoms on my 6500 and went to the DAX control panel and found channel 1 selected on for Receive and for Transmit. I was not using DAX at the time and it was not selected in the slice. I clicked the to un-select both Rec & Xmit. I have had no problems since deselecting DAX and the radio now runs perfectly.
  • Member ✭✭
    edited April 2015
    It could be that you don't have any DAX turned on in the DAX control panel.
  • Member ✭✭
    edited July 2017
    My 6500 froze last night during a remote PSK contact. After restarting SSDSr the chooser showed the radio was still connected which it was not (6500 had a red dot and the computer name next to it in the chooser window). I let it sit for about ten minutes and the radio finally showed a blue dot and was available in the chooser. Worked fine after that. I was using the latest mini deluxe and latest DM780 plus HRD log book.
  • Member ✭✭✭
    edited May 2020
    Tried to recreate the freeze enabling all four slices, each output a DaX channel, all I/Q channels active, remote audio to BT headset, various accessory programs for the SSDR running, SpecLab, etc. etc.   No freeze ups.
    The (free) program to show system IR latency was showing less than 500 u-sec IRQ response time.  Never saw it go above 1 m-Sec.
    System: 6500 / Windows 7 / direct independent 1GHz Ethernet connection.
  • Member ✭✭
    edited October 2016
    Never during any of the freezes, (in fact I rarely ever have more than 1 RX and 1 TX Dax open).
    And as all the 'freezes' occurred during JT operation, I did NOT have DAX IQ channels open.
