SmartSDR API - Panadapter ID - Question for 6500/6700 owners
IW7DMH, Enzo
Hello,
looking in depth in PAN and WATERFALL objects I found that they are assigned an unique ID.
In my 6300 they are assigned as shown below:
PAN 0: 0x40000000 WATERFALL 0: 0x42000000
PAN 1: 0x40000001 WATERFALL 1: 0x42000001
What is the schema for 6500 and 6700 rigs?
I have to do some assumptions for my software and I would be glad if you could help me.
Thank you in advance
73' Enzo
EDIT: I there a way to get the maximun number of Slices, Panadapters and Waterfalls that a rig can create?
73' Enzo
You know the model number from the Radio object. 6300=2, 6500=4, 6700=8
use a switch with 3 case stmts. The panadapter gets a spectrum and a waterfall, so really it is the # pans <= # of slices.0 -
Thank you very much Walter,
I'll immplement this logic in my class Contructor.
Also, do youn know what is the actual Id assigned to Panadapter 3 and 4?
Is it like in the example below?
PAN 3: 0x40000003 WATERFALL 3: 0x42000003
PAN 4: 0x40000004 WATERFALL 4: 0x42000004
and so on.
Thank you and '73
Enzo iw7dmh
No I don't, not off hand. BTW, I would caution against doing much more than creating the object in the constructor. Instance logic belongs in the methods, not the constructor.
There is no guarantee that they will be in order. The prefixes are guaranteed.0
Ok, as I am in a microcontroller enviroment building and destroying objects at runtime is to avoid due to heavy memory fragmentation.
So in my constructor I'll only instantiate a "right sized" array and then I'll set the correct ID, as I receive it from status messages. It should works.
In the last two days, working on the functions related to the "Display" menu, I experimented two subtle errors that can compromise the correct rig usage.
When I sent the following wrong command:
display pan set 0x40000000 fps=0
SSDR lost systematically rig connection and I had to restart it from scratch.
When I sent the following commands:
display pan set 0x40000000 min_dbm=%f
display pan set 0x40000000 max_dbm=%f
if max_dbm go over min_dbm and viceversa, SSDR freezes systematically. It can't help you restarting from scratch as SSDR save le last (wrong state) and it freezes again. I had to use telnet to connect the radio and set the correct value to both min_dbm and max_dbm. Then I restarted SSDR again.
Of course I edited accordingly my software but, supposing a remote usage, it could be safer if the rig could reject these wrong commands sending back and error message.
Thanks, Enzo. Issue #1933 has been entered for this issue.0
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
