Gritty
Neal_K3NC
Nice. Seems to copy quite well. Just select the same DAX RX channel you're using for your main RTTY application. It copied an EY7 calling CQ with fewer errors than MMTTY. Note: It wants a wide passband - in fact the help file specifically says it won't work well with a narrow filter.
Doug K4DSP
Yes works fine, with my settings it copied the EY7 about the same as MMTTY engine and 2Tone. Interesting that it seemed to default to my VAC , so no having to set audio devices. Max is 3 Khz , would be nice to get a bit wider. Auto QSX mode works very nice. N1MM Logger has now incorporated it as an option .
Andy K3UK0 -
I think if Alex does it, its done well (much like your stuff Doug).
I think that 2 Tone has eclipsed MMTTY for general decoding so will be interesting to see how it compares with that!
730
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
