SSDR 1.4.3 UHE (OutOfMemoryException)
rfoust
Got a unhandled exception from ssdr 1.4.3. I wasn't doing anything at the time, so not sure what triggered it. I don't think I've closed or restarted ssdr since I installed 1.4.3, it's been running nonstop till now.
Were you listening with the REMOTE option? My guess is that it's related to the codex in use?
http://en.wikipedia.org/wiki/Opus_(audio_format)Now then, did you find a little buggette? :-)
But wait, there's more! :-) Didn't notice at the time but there is actually another UHE popup at the same time. SSDR is currently using about 1.5gb of ram and I still have about 10gb ram free - I can still scroll the panadapters left/right but the data streams are pretty much frozen.
Yeah remote was probably enabled at the time. I should also point out that I've been using it exclusively over remote desktop - I've been pretty much receive-only lately.0
Looks to be a communication dropout, they can happen.0
I was in Wilmington for the past 4 days. Connected while sat on the water front a couple of times to listen around. Worked a treat. Probably no more than an hour at a time though.1
I am fairly certain that it isn't a connection issue0
I have entered this problem report into our bug tracker for additional investigation. Thank you for the defect report.
Just got another VitaSocket UHE same as the screenshot above, but not an Opus error this time. I didn't have Remote enabled this time either. My home computer is probably just unstable at this point so I'll reboot it (and probably the radio too) tonight.0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
