Two Minor Bugs
W5UN_Dave
W5UN_Dave Member ✭✭
edited March 2017 in SmartSDR for Windows
I'm using ver 1.4.3.
(1) at times when switching from SSB to CW the VOX remains engaged and can interrupt receive by triggering MOX if room noise is captured by the microphone.
(2) While using CWskimmer with DAX IQ I noticed that the sample rate will often (but not always) revert to 48000 instead of the required 96000 when changing bands or modes.
Dave, W5UN
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    Lack of DAX IQ persistence is a known bug that will be fixed in a future release
  • James Wilson
    James Wilson Member
    edited April 2015
    My 6300 got stuck on vox when changing from CW to SSB and cannot stop it. VOX button is not turned on. Have tried exiting SSDR v 1.4.3 removing 13.8 volt power source and rebooting computer, with no success. How can I disable this VOX lockup ?
    All Help is greatly appreciated
    Dave Wilson
    N5DBS
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited November 2016
    As Howard said, I believe it's always been that way, or perhaps started in earlier release.It's relatively easy to resolve, quickly mark the xmit slice to usb, turn off vox, then switch slice back to cw.
  • Tim - W4TME
    edited March 2017
    #1 has been written up in our bug tracker for further investigation.
    #2 is a previously reported issue and is already in the bug tracker.
    Thanks for the reports.
  • Eric-KE5DTO
    edited February 2017
    Dave,
    We fixed several problems related to VOX in v1.4.11.  Do you continue to have this problem on the latest version?
