change active slice
Joe Veras
Running SSDR 1.43 with Flex Control. On the Flex Control Settngs pull down, there is no <Change Active Slice> option. What else do I need to do? Thanks!
Hi Joe,
Does your drop down look different than the snapshots below?
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Yes, Al, it is different. There is neither Change Active Slice nor Mox listed.0
That sounds like you aren't running the latest version of the SSDR software. Since the version is not on the main screen, you have to look in the settings to see your SSDR client software version. Does it look like this?
Regards, Al / NN4ZZ
That's where I had gone wrong. I downloaded and installed what I thought was the latest version of 1.4 . . . but it wasn't. After looking at your screen capture, I did it all over again and am happy to say it is now working like a charm. Many thanks, Al!
-joe-0 -
Joe,
Good deal, that is one reason I suggested adding the version to the main screen. It would make the version clear and obvious. Add your vote and comments to the idea below if you would like to see it. It's easy to miss as it is now and would have saved you some time and effort.
https://community.flexradio.com/flexradio/topics/smartsdr-version-in-the-title-bar
Regards, Al / NN4ZZ
Thanks again, Al. Your fully and well-illustrated tutorials did the job! Having spent 4+ decades in the photo business, I appreciate the value of pictures.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
