DAX in 1.4 and 1.4.3
Sergey R5AU
Win 8.1 and Win10 TP
F6700
SSDR 1.4 and 1.4.3
FLdigi 3.22.06
After couple of minutes with DAX utilization for DIGI mode unable to receive any signal - signals on FlDigi waterfall not clear,smeared, necessary to restart DAX completely to get back signal reception. Any body has such behavior ?
screen shot from FlDigi with bad signals is:
after DAX restart:
F6700
SSDR 1.4 and 1.4.3
FLdigi 3.22.06
after DAX restart:
My first installation of 1.4.3 didn't load DAX correctly and I got errors and disfunction.
I completely uninstalled all parts of SSDR, including DAX and CAT and now things are going well.
Remember to make sure you have set your sound interface properties to 48,000 on both ends of every virtual cable in the Sound properties tab in Windows.0 -
Sure Ken, this is not with W10 first Beta release and after upgrade to the new beta, but with my Toshiba Notebook with Win8.1 also, BTW everywhere 16bit 48kHz
Of course i retrieve the error message after W10TP upgrade to the new beta release and reinstall SW with WIN restart and with deleting DAX drivers, also make already radio restart with power+OK
BTW after DAX restart - trouble free for unlimited time0 -
May be i find out the issue:
in DIGI i have just keep as a copy from SSB BAL input:
i think what BAL automatically switched off in case DIGI and DAX selected
however after selection of the Line input this issue not appear
keep selected LINE input for DIGI, will test it.
For the last 30minutes result is:
DIGL/DIGU + DAX do not switch off other signal input completely
Ken, can you check it please ?0 -
I will take a look tonight when I return to the shack.
Ken - NM9P0 -
Yes. I suspect you are experiencing a driver level buffer issue that is usually DPC related. Try running LatencyMon (http://www.resplendence.com/latencymon) and see if the PC is suitable for streaming audio applications0
Well, test results with Latency Monitor:
DAX issue ?
BTW, just for information regarding W10 Tech Preview
due to the running on the W10Preview, yesterday upgraded on:
SSDR necessary to reinstall completely as was already mentioned here, but, some audio services not started in any way properly:
Next step is close DAX and start Troubleshooting for audio services with positive result
and start DAX again:
Final solution is:
1. Reinstall SSDR
2. Disable from start up DAX
3. Manually start troubleshooting with audio services - always solving error message
4. Start DAX manually again
I believe this is W10TP issue however, not everything clear regarding DAX behavior.
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
