slice dump settings
Not sure I 100% understand your question. But if you send command "sub slice all" it will return all the information on current open slices. It also subscribes so that all future changes will be sent to the client.
But not sure if this is what you were asking.
William
William, that is what I am looking for, but I'm looking for a way to do it using the FlexLib API. I think the sub slice all is a TCP/IP command.
Edit: provided incorrect info -- looks like the sub commands happen after you connect() to the radio. Try adding a sleep/delay after you connect to give it time to get the data. This is from radio.cs: // subscribe for status updates SendCommand("sub tx all"); SendCommand("sub atu all"); SendCommand("sub meter all"); SendCommand("sub pan all"); SendCommand("sub slice all"); SendCommand("sub gps all"); SendCommand("sub audio_stream all"); SendCommand("sub cwx all"); SendCommand("sub xvtr all"); SendCommand("sub memories all"); SendCommand("sub daxiq all"); SendCommand("sub dax all");0 -
Hi Mark,
You're exactly right: The Slice and Radio Property Changed callback is exactly that. It's called when the value for a property changes.
As soon as the slice or radio instance is created you can read the value of the property. For example, I do this for a set of Slice properties directly in my Slice Added callback:
private void radio_SliceAdded(Slice slice)
Debug.WriteLine("radio_SliceAdded fired
_theSlice = slice;//
// Initialize the slice attribute displays
// We don't get a "changed" event if a slice already exists when we start.
RxFilterLowTextBox.Text = _theSlice.FilterLow.ToString(CultureInfo.InvariantCulture);
RxFilterHighTextBox.Text = _theSlice.FilterHigh.ToString(CultureInfo.InvariantCulture);
rxWidthTextBox.Text =
( _theSlice.FilterHigh - _theSlice.FilterLow).ToString(CultureInfo.InvariantCulture);
AGCTrackBar.Value = _theSlice.AGCThreshold;
currentACGLabel.Text = _theSlice.AGCThreshold.ToString(CultureInfo.InvariantCulture);
// Display the current frequency
VFO1.Frequency = _theSlice.Freq;
... (etc) ...(Man, it's hard to post code in this forum... I wonder if we can get a plug-in or something installed that'd make posting formatted code easier and prettier).
Anyhow, pretty easy, huh??
Peter
K1PGV
I tried setting the ProgramName and I'm still not seeing the properties that are already set on the slice.
I think I have have to do that.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
