FlexLib getting the active slice current band
MikeColonna
Hello, Tonight I have successfully connected to my 6300 through the FlexLib. I gather up current frequency and mode from the active slice. But what I can’t figure out is how to get the current band? Do I have to create a band plan then based on the frequency then figure out what band I’m in? Or is there a way to get this information from the active slice. Thanks Mike AA5MC
Mike,
The band is a property of the panadapter class. You should be able to use the Slice.Pandapter property to obtain the panadapter object that the slice is associated with & then read the Panadapter.Band property to get the band.
73, Ray, K9DUR
Outstanding, thank you I'll take a look there...
Mike, AA5MC1 -
In the slice added event do something like this:
string bandinfo = slice.Panadapter.Band;
lblBand.Text = bandinfo;
Works for me and when you change bands in SSDR it automagically updates!
james
Saw your post days ago, but, I was out on the road and unable to post the code from memory and I didn't have my little Nextbook with me either.0 -
Looking at a later post by you, it seems you already figured this one out!!
james
Hi James , yes I did but I appreciate your answer . thank you1
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
