WSJT-X JT65 settings help requested pls
2»
  • Member ✭✭
    edited August 2016
    Bob, this is indeed the case. The real puzzle is that the values that were changed were at their default values. We were surprised that many others don't have similar issues to mine. Decodes up by a factor of four - going to enjoy JTx tonight.
  • Member ✭✭
    edited August 2016
    Good , your seeing progress. Can I see a shot of the main window while its running and decoding?
    73, Jay
  • Member ✭✭
    edited August 2016
    With pleasure. Need 2 rows of callsigns in JTAlert now <g>.image
  • Member ✭✭
    edited August 2016
    So you like 1.5-devel? which -r#### your using? I haven't checked for updates in a couple of weeks.
    73, Jay - NO5J
  • Member ✭✭
    edited August 2016
    r5089. No bugs found at all, very smooth.
    Sadly, I cannot compare like with like as I was upgraded before the fixes. Are there pre-compiled Windows binaries for 1.5 available?
  • Member ✭✭
    edited August 2015
    I use this to keep clock in sync, works like a champ..
    http://www.worldtimeserver.com/atomic-clock/
