Heil HM-12 Microphone Cable
Member ✭✭✭
I am looking at purchasing a Flex 6500. I already use a Heil HM-12 microphone on a Elecraft K3. What microphone cable would I need to purchase so that the HM-12 would be compatible with the Flex 6300 or Flex 6500?
Welcome!
  • Member ✭✭✭
    edited May 2018
    The CC-1-Y Yaesu adapter will allow you to connect to the front panel MIC jack.  I don't know if the HM-12 has a balanced output to go to balanced cable to the rear jack or not, but if so you could check that with the Heil folks.
  • Member
    edited January 2017
    Flex uses the same pinout as Yaesu for the foster mic jack.  Heil has premade cables.  You might also want to look into a cable for the balanced line mic input on the rear of the flex.  I also have the HM-12 and have been pleased with it.
  • Administrator, FlexRadio Employee admin
    edited March 2017
    You would need the following cable to connect the HM-12 to the 8-pin Foster connector on a FLEX-6000.
    http://cart.flexradio.com/HM-PRO-Mic-Cable-for-8-pin-Foster-connector_p_38.html
