Changing band by CAT does not change to the concerning antenna
Luis del MOlino
Own a Flex 6500 and I have dipols for 80-40-30 and a Yagi for 20-15-10 meters.
If I change bands in SSB or CW, each band conects to the right antenna, but if the band is changed by a digital CAT program that changes frequency, the band changes acordingly but the antenna remains always the last used unchanged and do not follows the band change.
That means that if I am not aware of the last antenna used, I often start transmitting into the wrong one with a very high SWR. Fortunately, Flex 6500 seems not impressed by a couple of seconds of infinite SWR, until I can stop transmission and place the right antenna for that band..
This problem was already present in SmartSDR 1.3.8, but I see it remains unchanged in 1.4
Luis EA3OG
Luis EA3OG
We had an issue on this, #1269, which was fixed in v1.4. The issue was that persistence data was not used on a tune in CAT. Can you tell us what the specific CAT command is that is being sent? I suspect the one we fixed this for is "FA".
Steve:
I have been confirmed by the author of the digital program that the CAT commnad sent to change frequency was FA, so it seems that has not been well "fixed".
73 Luis EA3OG0 -
I have reopened this defect for additional investigation. Thanks for the report.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
