Focus helper interrupts right-click
Greg Zenger [N2GZ]
I just setup focus helper for the first time with N1MM+. I have found that if a slice is off the visable pan adapter and I right click on the 'slice off panadapter' notification (e.g. "B>") I am unable to access the context menu to hit 'delete slice' because focus is immediately returned to N1MM and the menu goes away.
I presume this is a bug?
Flex 6700, SSDR 1.4
Flex 6700, SSDR 1.4
I found a work around:
If you right-click on the 'slice off panadapter' notification and immediately left-lick-and-hold you can then drag your mouse pointer over the 'close slice' option. Likewise, to access the File/Settings/Profiles/Help menus, left-click-and-hold over the menu, and while holding drag your mouse pointer over the menu item you wish to select.0 -
So that's what was doing it! That behavior was driving me bats. It wasn't part of my initial experience with 1.4, but it had started doing it recently. Your post reminded me that I had activated "Focus Helper" a few days ago. I solved the problem by changing the time delay to 1100 ms. instead of 100 ms. Everything still works fine, but i must wait a second before the focus is back to my logging program. I will see if this works OK. Thanks. I imagine that there are a few other actions that would be affected by this.
Ken - NM9P0 -
You can also set the time that it stays there before returning in teh radio setup tab
I use 2000 msec for Writelog
I have entered this report into our bug tracker for further investigation. Please report any additional information related to this specific issue in this community topic.
Yea, I changed the time delay (100ms seems mighty tight!) to 1100 and it works very naturally.0
- 113 SmartSDR+
- 944 Maestro
