Strange TX spikes 20m
W4WHL
W4WHL Member ✭✭
edited March 2017 in SmartSDR CAT
TX on 20m does not look right.  The panadaper shows very wide with strange spikes, but only on 20m.  I never noticed this with 1.3.8.  Its hard to explain so I will just show the Video below.  The rig is the Flex 6300, power is set to 5w into a dummy load.  First I show the TX panadapter on 10m and it looks smooth and clean.  Then I switch to 20m and transmit.  As you can see the patterns are very different.  The base becomes much wider and looks jagged.  I have tested this with remote and direct connected mics, so its not RF getting into mic.  Any ideas?
https://www.youtube.com/watch?v=DozNY5QM1UQ
  • Tim - W4TME
    edited March 2017
    This is normal - nothing to be concerned about.  Your radio meets all requirements for spectral purity on transmit. You are seeing a very low level artifact in the that is generated internally in the radio and NOT transmitted.  Note that the signal level is around -130 dBm (as best as I can tell).
    Also, in the 20m test, you had left the RF Preamp on and that was what was causing some of the display "spikiness".
    In FlexRadio support, there is a saying we have since the first panadapter was coded in PowerSDR, many moons ago; "the best thing about the radio is the panadapter and the worst thing about the radio is the panadapter",  This comes from the fact that now you can see RF artifacts, birdies, noise and other RF stuff that had always been there with other radios, but now you can actually see it with an SDR.
    We debated about blanking or deliberately modifying the display to hide the low level symmetric side band signal peaks on transmit and in the end decided it was best to show the spectrum as it is on transmit than to do anything artificial.
  • W4WHL
    W4WHL Member ✭✭
    edited July 2016
    Thanks Tim!  I was just making sure.  Thanks for the explaination!
    William
  • Steve-N5AC
    Steve-N5AC Community Manager admin
    edited February 2017
    There is one other key difference in the two panadapters that is subtle.  On 20m you have the panadapter Weighted Average function turned on.  This favors the peaks in the panadapter and causes a drastically different look for the same data.  Try turning this off and comparing also.  I wrote a more detailed explanation of this function in this post:
    https://community.flexradio.com/flexradio/topics/weighted-average
    Gerald explained the low-level spurs seen in the receive panadapter during transmit here:
    https://community.flexradio.com/flexradio/topics/panadapter_spurs_in_tune_mode
    In general, the receive pattern of the transmitted waveform is useful to see, but do not look too closely at any spurs out of the local transmit filter.  In almost every case these are caused by the proximity of the receiver and transmitter in the radio and are not actually being transmitted.
