AGC setting
Walt - KZ1F
While I like Al's suggestion on automating the setting of the AGC-T to place it at or above the noise floor automatically. I seem to recall this working better on 1.3.8 but with 1.4 and on a fresh 1.3.8 the default setting, which is 65 is way to high. Short of implementing Al's suggestion, could the default be around 30?
Walt Corey - kz1f
Walt Corey - kz1f
Just set it where ever you like it and save it. Makes do difference where the factory default it.cause everyone is going to change it anyway....
When you say 'save it' what are you referring to? In Global Profile, because that doesn't work which, as I read what I wrote, I was saying. It doesn't persist. I believe, under 1.3.8, it did, at least it over a shutdown and restart. Ergo, rather than have 65 be the default, set it to something reasonable.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
