Lower right side of 5th setting window not scaling properly in full screen mode
K2CB Eric Dobrowansky
When SDSR is in full screen mode, the fifth lower right setting window is not scaling properly. For example, when the EQ window is in the lowest most position, the lower 25% is being chopped off. However, the waterfall looks to be scaling properly. I am using 1920x1080 as the resolution setting.
Also, will the scaling be addressed so that in a reduced window, the five boxes scale proportionately? It is a real PITA when trying have multiple apps on the screen at once (Log, SDR, etc...)
Not all of the sidebar windows will be in full view when SmartSDR is maximized based on several factors such as scaling and monitor resolution. There is a feature request to address this in the future. In the mean time, unused windows can be hidden, such as the EQ windows which im most cases while operating should be a :set and forget" type control.0
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 968 Maestro
- 940 Genius Products
