RT Systems to SmartSDR 1.4 Memory Importer
K6OZY
Member ✭✭✭
Now that 1.4 is out, I can start trickling out my tools and videos I put together during the development window. This is a script I wrote during 1.4 development to import my RT Systems CSV file into SmartSDR. Enjoy!
https://github.com/Ozy311/HamStuff/blob/master/HamStuff/rtsystems_to_ssdr.pl
Here's a sample run:
./rtsystems_to_ssdr.pl
Flex 6000 Series RT Systems To SmartSDR CSV Memory Converter v1.0
(C)2014 Chris Johnson K6OZY k6ozy[at]arrl.net
Usage: ./rtsystems_to_ssdr.pl -f RT Systems CSV File [-o owner] [-g group]
-f : Exported CSV from RT Systems Programmer
-o : Owner of imported Memories [optional]
-g : Group name of imported memories [optional]
./rtsystems_to_ssdr.pl -f ./RTSystems.csv -o K6OZY -g "AZ Repeaters"
Custom Name: K6OZY
Custom Group: AZ Repeaters
422 lines consumed.
SSDR_Memories_2015-03-16_17-31-30.csv
It then drops a CSV in the current directory for you to import into SmartSDR.
Custom Name: K6OZY
422 lines consumed.
so do you have a step by step on how to use your script to import the rts memory
Bret
Do you have the ability to run perl scripts? Are you running this on a Windows or Mac? I use a mac and perl is native in the OS. If you are using Windows, you need to install perl first.
http://www.activestate.com/activeperl/downloads
Install that, copy my script from GitHub into a file ending with extension of .pl and try running it from a command prompt.
You then export your RTSystems setup as a CSV file and feed it into my script adjusting the details from my examples in the post above.0
- 379 Community Topics
- 631 The Flea Market
- 121 SmartSDR+
- 193 DAX
- 39 Aurora
- 262 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
