Full Screen not full screen v1.4
W4WHL
V1.4 in full screen mode does not take up the entire screen. The window does not extend all the way to the right. A small portion of the desktop can be seen down the right edge. Not a major issue, but a bit annoying cosmetically.
Other than this minor issue, v1.4 seems to work great.
W4WHL
W4WHL
2
This is not a bug. This is a new feature that prevents the SmartSDR console from being obscured by the task bar. If you do not have a taskbar on your monitor at the bottom where SmartSDR is in full screen mode, there will be a gap.1
Tim,
I'm not talking about the bottom, this gap is on the right side. After testing this gap does not appear on 1080p and above displays but it is there on 2 laptops that run resolution 1366 x 768. i will get a picture later.
Regards
Yes. pictures please!0
I have the gap all the way down the right side when running v1.4 in full screen. I am running 1080p. Let me get a picture.
Here's a pic that I took of just the right side of the screen while in full screen mode in 1080p.
Yes that's the exact issue I have! Thanks. Yes that gap on the right side is annoying, but just cosmetic. But I would like to see it fixed.
w4WHL
Oh, that is just a few pixels. This has to do with DPI scaling. Are you using Win8 or greater?0
I'm Win 7 64 bit
I have tested win7 64, and win 8 64 both exhibit the same thing on the right edge.
I see what you are describing. This is already in our bug tracker for additional investigation.0
Only this morning I have this issue. SSDR will not scale to full screen as all other apps do. I can't drag it bigger either. I am not sure why this only happened this morning? Strange.0
From what I have experienced, this only happens on my monitors that use 1400x900 resolution. It does not happen on my screens using 1366x768 or 1900x1080.
William
I just started using a second monitor and it is running at 1920x1080 and SmartSDR takes up the entire width but leaves 2 inches of open desktop space on the bottom. Is this a bug or are there some adjustments I should make?
If I reduce the resolution to lower values SmartSDR will fill the screen properly but the recommended and native resolution is 1920x1080 so I would prefer to use the correct resolution and not have to make a change only when I use SmartSDR.0 -
Support ticket submitted.0
- 384 Community Topics
- 650 The Flea Market
- 150 SmartSDR+
- 263 SmartSDR CAT
- 288 FLEX-8000 Signature Series
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 802 Peripherals & Station Integration
- 142 Amateur Radio Interests
