where is smartsdr 1.4?
G4YDO
perhaps you should change your policy on "not biting" good luck steve g8jut0
They gave it to people in third-world-countries. They have so little, and we have so much.
Just wait a while (and then some more), and a few copies may get released to YOUR country :-)
As Jim Morrison used to sing, waiting...
https://www.youtube.com/watch?v=A0kypyGSKsE
BTW my favorite song...0 -
Ok, another one, just saw this poster at the local Sherriff's:
W A N T E D
SmartSDR 1.4
Alive only!
Reward:
50 years free membership in this forum0 -
From Gerald last week
There is not a great deal that I can add other than what Steve and I have posted here before. I will, however summarize a few points that have been made here on multiple previous occasions:- We first published a public road map for SmartSDR in the summer of 2013. V1.0, v1.1, and v1.2, were exactly on schedule from the first dates published. v1.3 was only two weeks later that the date originally published over a year earlier.
- v1.4 is the only release that was materially later than the first published road map. That is based on the original estimate made in the summer of 2013!
- The reason v1.3 was two weeks late is that we applied engineering resources to perform preliminary research for v1.4 in the area of LAN remote data compression and the Waveform API/FreeDV during the v1.3 release cycle.
- This past October we announced our intent to do a v1.5 release that focuses on noise/interference mitigation enhancements along with system performance enhancements.
- As we went into full development of v1.4, we decided that we should perform end to end system performance tuning that we had originally planned to do in v1.5. As Steve reported a few days ago, this is a real time, multiprocessor client/server system with over 40 parallel threads. We performed significant surgery under the cover that has radically increased end to end system performance as well as decreasing the PC power required for the client. When you do that kind of surgery, it requires significant stability testing and debug cycles. This cannot be rushed.
- v1.4 is running now on low end PCs that completely choke on v1.3.8. My i7 went from 70% loading on 8 cores with v1.3.8 to under 15% loading on only 4 cores with the v1.4 test release. That is running with 8 panadapters, 8 slices, and 8 DAX streams. Network loading with 8 slices running remote LAN without DAX is running only ~8 Mbps.
- We have been unwilling to release v1.4 until we are satisfied with its stability and reliability. I stand by that decision unequivocally.
- The current test release of v1.4 is now very stable but I will not give a date for release. On the day we release we will put out a public announcement through the Flex Insider.
- The engineering team has now moved to planning and design for the next point release.
- We are planning to move to shorter release cycles beginning with the next release. That means more frequent but smaller releases (a.k.a. Agile). It also means that there are likely to be more point releases than in the past.
This will be the last post I make on this subject until v1.4 ships. ;>)
Gerald
8
- 255 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 789 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 737 Genius Products
- 394 Power Genius XL Amplifier
- 256 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 588 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 815 Third-Party Software
