Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
My New "All Flex" HF station....
- 67 Community Topics
- 1.9K New Ideas
- 118 The Flea Market
- 5.3K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 84 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 66 DAX
- 278 SmartSDR API
- 7K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 553 Maestro
- 14 FlexControl
- 721 FLEX Series (Legacy) Radios
- 147 Power Genius Products
- 116 Power Genius XL Amplifier
- 10 Power Genius Utility
- 21 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 88 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 61 Amateur Radio Interests
- 402 Third-Party Software
Thanks Mark (now I know I'd rack mount em) errr Stack em.
The Wheatstone Vorsis M1 answered another question.
Question now is. How much is an M1 and how soon can it get here?
Same exact question I had when I fist saw the FLEX6500.
Wow! durned internet just keeps spending my money.
Answered my questions and decided I could just dream about the Vorsis a little longer. You have my envy, Mark
73, Jay - NO5J
Walt
Howard's power setup and other good stuff is in the How to build a quiet station
https://community.flexradio.com/flexradio/topics/how-to-build-a-quiet-station
Good reading
Dan --- KC4GO
My dictionary appears to be more general and less self-serving. There are 6 other meanings of which only 1 relates to money.
e.g. a devoting, using, or giving of time, talent, emotional energy, etc., as for a purpose or to achieve something:
I invest time with personal satisfaction as the dividend (non financial definition)
I realize this is a comment on someone else's thread but speaking of 1.4...What do people perceive they are going to use as a remote? I really believe the notion of operating from the BBQ pit will prove problematic. There is 'one can' and then there is 'one wants to'. But, hold that thought, I am close to unveiling a kick-**** solution, well, if you like Android.
james
Walt
If that four-color full-page add said "Come in and add to your debt", you would likely stay home.
I keep the 1500 for five reasons....
1) I use it to monitor my 6500 when I make audio adjustments. The "Spectrum" display is a great help to balancing my SSB audio profiles. I have about 4 or 5 for various purposes on SSB with my main mike (Heil PR22UT) and several others for legacy and experimental mikes, including boom headsets, etc.
Nothing beats recording myself on a quality receiver and playing it back on the same speakers I use on my main rig. Listening to myself via headphones just doesn't cut it.
2) I want to be able to use it for another dransverter in event that I someday use two (one on each flex) in order to work Satellites full-duplex. Or If I want to use a transverter while also working HF. Since the 6500 doesn't have 2 SCU's this is one way I can receive multiple bands on two different antennas.
3) I want to be able to set it up to run WSJT-x or WSPR on a different antenna as a dedicated outfit,
4) It is fun to brush it off and run QRP. Occasionally I will switch in mid conversation with my rag chew bunch and see if anyone notices. When all they say is that they noticed my signal dropped off in strength, I know I have the audio set just about right!
5) It makes a nice emergency back-up rig. If something happens to the Big Kahuna, I can just throw the antenna switch and PTT line switch and I'm good to go.
Ken - NM9P
Here is a image of how to hook up a PowerGate so that your station basically runs from DC Power
At least on receive or if you have very large batteries (I have 200AH) then you will be on DC most of the time... On transmit, you will start to run down the battery and the Powergate will allow the Powersupply to charge the batteries..
The Powergate has built in Hysteresis so that even though the Supply Voltage is higher than the battery, it does not cut in right away...
TV on desk? TV's belong on the wall....
Here is a shot of the other side of my ham shack...where I do most of my writing and other work besides ham radio
Some day when I actually clean up my office/shack (Don't tell my XYL that my office can actually be cleaned up) I will do a full pictorial of the layout.... But right now...too much test equipment, parts and stacks of paper on the desks to make sense of it...
Of course, with multiple computers and lots of 27" monitors, virtually total automation of everything, I can work my 6700 from a number of different positions around the room...but for serious stuff like contesting, it's better to use the 3 monitor workstation that I dedicated to the 6700 on the other side of the room.
That excuse only works for you...
What do I use as an excuse when XYL has the bad back
