Sound Issue With Remote Operation on Flex6300
Thanks Jim!0
I have a 6500 and have the same issue. It is not unique to the 6300.0
Dave, wo2x
I should have noted - I have the 6700. The problem appears to be in DAX and does not appear to be model specific.
Wow! Thanks for pointing this one out!
I suspect that since Microsoft controls Skype they have planted all kinds of stuff for backdoor adware insertion and eavesdropping. Plus with all the hoopla surrounding privacy concerns, they probably planted some weak form of encryption atop it all. It just all bogs things down.
Of course, no guarantees that our German friend didn't do the same, but he is a Ham and deserves our assumption of trust until otherwise proven. It seems to work very well. Comparing to the Icom RS-BA1 right now.
73 de Dave, N7AIG
FWIW... I get the exact same issues when listening to Youtube videos while running a whole bunch of other stuff on screen -- FLDigi + HDSDR + PowerSDR + VAC + ...
I firmly believe that it all has to do with processor loading, because once I shutdown some of the other stuff and refresh the video, the sound plays back normally. So nothing to do with SmartSDR per se, but rather the combined processor and network loading. Of course, SSDR could help by being a bit more efficient. But then someday a lot of other useful tools will appear and begin to bog down the whole system again.
73 de Dave, N7AIG
... I call this the "Fish Tank Syndrome"... look at fish in any aquarium and you see them always swimming to the bounding glass. Same with us...0
My loading is minimal < 15% CPU and slight disk usage. Mem usage also low. Your issue is different.1
Same as Guy!
My system when this happens:
CPU 10-12%
Memory usage 800Mb
Network 1.2MBPS (1 gigabit connection)
No chance this issue is lack of system resources. Its a bug for sure!
W4WHL
CPU is not the resource that is critical for real time audio processing. You should be investigating if you have long duration DPCs (deferred procedure calls) using LatencyMon.0
I've ran Latency Monitor while connected with CommCat's VoIP. The audio starts "motorboating" after several minutes but Latency Monitor remains green. I toggle DAX off then on and it clears up for several more minutes before reoccuring. I loaded DA X 1.05 in place of DAX 1.10 which was installed with SSDR 1.3.8. The audio motorboating did not happen in a 20 minute stream. It appears there are issues with DAX 1.10 and my Windows 8.1 system. Just an FYI, PowerSDR 2.72 with Flex 5000 and VAC 4.14 run perfect. Dave, wo2x1
Hi Dave Wo2x, I've talked to you a couple times in the past on the montclair (Wo2x) repeater
Name is Mike
Hi David,
Same here with DAX. No DPC hits (Tim, thanks for pointing this out) on my machine (recent i7 PC, Win 7 64-bit, with good graphics). DAX 1.3.0 exhibits the stuttering (motorboating) only occasionally (days). DAX 1.3.8 has the stuttering frequently (every few minutes). In either case, clicking the DAX panel blue channel enable button OFF then ON fixes the audio temporarily.
DAX 1.3.0 (maybe only with SSDR 1.3.0?) has other problems with level indications, but at least they are predictable and I have been using FLDIGI, WSJT, and RMS Express (WINMOR) successfully with it.
I have not tried mixing DAX 1.3.0 with SSDR 1.3.8. Tim, is this a workable combination?
73, Bob, N7ZO0 -
Yep, it is still up on the air. Installed a new PA last fall. Primarily on 442.000 on way to work in morning (6;15 to 7:00)0
Yeah I listen from time to time, I run an echo link node for Montclair for Barry K2mf and others to use.
I will stop on 442 in the morning next time i am up that early. I heard you were in to flex radio from some of the guys. I just got a 6300.
LatencyMonitor stays green during the popping and goes red when there is none. It complains about CPU throttling (ain't any) and tcpip.sys having the highest execution.
OS: Win 7 x64 with all the updates.
If you are not having DPC hits greater than 1000 uS, then I suspect (I have no definitive proof of this) it could be a buffer corruption issue. We have made changes in SmartSDR v1.4 to address streaming inefficiencies and that may clear this up.1
Ok thanks! (Fingers crossed) Dave, wo2x0
Thanks Tim.
I dont have high DPC hits (highest is 163) but my process latency highest is 4569:
http://i.imgur.com/GS22qAd.png
I'm just hoping they release 1.4 before I leave for KH6 so I can have it online.
Dave, wo2x
Make sure to leave TeamViewer installed, might have to install 1.4 remotely....
Yep.0
1.4 is LAN based not WAN....that is for 2.0 and above.0
Yes, but we are hoping 1.4 has a more stable DAX audio driver (which Flex stated there are DAX improvements). Also there should be additional bug fixes rolled in as well.
I for one would like to see improvements to AGC slow operation on SSB. The hang time is too slow.
So, I will be running my radio remote but it would be better with 1.4 if these improvements are rolled in as well.
I would love to see more point releases addressing bug fixes along the way, especially if the time between releases increases. But I understand this is not practical because it would require parallel branch development which would require more resources and have more complications .
Hopefully this speed bump in development is a one time thing due to the complexity of adding the audio codec into the radio and future releases come out quicker.
Dave, wo2x0 -
Careful on remote upgrades -- you will probably need to reboot both the radio and computer in the process. Consider having a remote power switch capability if you want to live on the edge with a long-distance upgrade.0
I have used TeamViewer to upgrade software and install updates that required a reboot on family´s PCs and worked like a charm.
Nonetheless I agree, good to have a neighbor or friend with keys for a hard reset, reboot, just in case.
Biggest issue, a problem with the router.0 -
I hooked my gear up to a web switch v7, its a must have for a remote operation IMHO. I have had my flex lock up 3 times on me in the 1 week I have had it.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
