Questions about AGC-T algorithm
IW7DMH, Enzo
IW7DMH, Enzo Member ✭✭
edited May 2019 in SmartSDR for Windows
Hello, I read the "DIRECT CONVERSION RECEIVERS" White Paper of Stephen Hicks and I have some questions about the AGC-T function and its related control.
1- is the AGC-T funcion implemented in the same way in the new Direct Sampling Receivers?
2- if so, what is the real effect of the sliding control when AGC dropdown control is set to OFF?
Probably I am missing something, but when AGC is OFF the algorithm should not modify gain in any mode. On the contrary, expecially for dx little signals, I find it very effective (also when AGC is OFF) and can make the difference between copy or not copy a small signal.
73' Enzo
iw7dmh
  • Tim - W4TME
    edited March 2017
    AGC Off disables the automatic gain adjustment algorithm and allows you to set (fix) the gain manually.  It will not change in response to the received signal strength.
  • Kevin WB4AIO
    Kevin WB4AIO Member
    edited December 2016
    I monitor the levels coming out of my system with an average-reading VU meter. (Either James Chapman's VUMeter program or the VU section of the free Orban Loudness Meter.) I adjust the VUMeter scale so strong signals read about 0 VU on frequent peaks.
    Then I tune off to a point in the band where I hear no signals, just normal band background noise. I then adjust the AGC-T for a reading of -15 dB on the VU meter.
    For me, that is the magic spot where signals "pop out" of the noise, without the noise being fatiguing to listen to -- yet weak signals are still strong enough to understand. This would apply to PowerSDR or SmartSDR.
    I also almost always run Custom AGC settings (this relates to PowerSDR; not sure about SmartSDR settings). I keep the normal 2 ms attack time; that sounds best. But I slow the recovery time down to its maximum setting: 5000 ms. (I actually wish I could make it a bit longer.) This makes listening a real pleasure. Only in severe thunder static conditions do I use one of the default AGC settings to get a faster recovery time between crashes.
  • Jay Nation
    Jay Nation Member ✭✭
    edited May 2019
    Kevin
    Funny. I thought I was the only one doing that. Including the Oban meter, but not the James Chapman VU meter, hadn't seen that one. Have you looked at FlexMeter-1.0.0.5?
    https://community.flexradio.com/flexradio/topics/a-small-utility-to-read-smartsdr-radio-metering-points-with-ethernet-api. It reads out the levels that the radio sends to SmartSDR. Even if SmartSDR doesn't show them to you, the radio knows what it's doing. We juat have to figure out how to interpret the numbers its putting out.
    73, Jay - NO5J
  • Jay Nation
    edited May 2019
    Hadn't paid real attention to the numbers from FlexMeter, until now. but tonight on 20m monitoring WSJTX with a 50Hz filter width of the noise floor during the quiet intervals.
    the SLC LEVEL 0 reading is -121 dBm.
    the SLC AGC+  0 reading of that 50Hz is -39dBFS.
    the SLC 24kHz 0 reading  of that 50Hz is -103dBFS.
    widening the filter back out to 3500 Hz dring the quiet intervals
    the SLC LEVEL 0 reading is -99dBm
    the SLC AGC+  0 reading is -16dBFS + or - 1dBFS
    the SLC 24kHz 0 reading is -103dBFS + or  -1dBFS
    It's a guess but SLC LEVEL 0 might just be the current SmartSDR Smeter level in dBm they seem to track together.
    Another guess is the SLC AGC+  0 level might be how much AGC gain is being applied. 15dBFS seems to be the reading of what I'm trying to adjust the AGC-T to acheive, the way I normally set things up.
    Another guess the SLC 24kHz 0  -103dBFS not changing much might be explained by a 100dBm birdie in the passband. its usually the same reading unless a stronger signal gets dropped across it.
    putting a narrow TNF on it makes it drop a little.
    Maybe someone at Flexradio can define the meaning of those 3 levels they send to SmartSDR?
    But I do like the -16 to -15dBFS reading for the SLC AGC+  0 measurement that probably has nothing to do with the -15dBm reading i got from the Oban meter when
     I was searching for the sweetspot for AGC-T setup.
    All of this was done with Preamp set to 0, AGC speed set to fast, AGC-T set to 50, DAX RX gain set to 20, and WSJTX set with the slider centered on the 4th index from the bottom and the WSJTX level meter reading 10 dB during the quiet Intervals.
    My usual method is switch to dummy load, set DAX to 20, set AGC-T to 50 and read a 0dB level on the WSJTX level meter. then switch to the antenna, the level will jump up to 9 to 10 dB during a quiet interval, and rises to almost 20dB when it hits 20 I lower AGC-T 1 notch, when I see the quiet intervals drop below 7dB I raise AGC-T one notch.  total adjustment range of AGC-T is between 47 to 51, but it ends up most of the time set at 50. On 40m I use the -10dB attenuator and adjust the same way.
    73, Jay - NO5J
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    Absolutely fascinating. A lot of it goes over my head but I still like reading your technical posts. Many thanks and keep posting.
  • Jay Nation
    edited August 2016
    Steve
    Wow, thanks for this explanation. These are the types of things I'm curious about. I'd like to be able to understand it "all". Each new detail helps explains a bit more of the mystery. Give's me more pieces of puzzle that I hope will move me closer to solving the puzzle and assembling the "big picture". The more in focus that picture becomes, the more ideas I get about using the SmartSDR API, and SmartDSP API. When I know more about what the radio is doing, I can wonder more about what it might be able to do. Then I can move on to the what can "I" make it do. It's already capable of so much, I'm usually to busy enjoying it, to worry about, "but what else?".
    Thank Youimage
    73, Jay - NO5J
  • Jay Nation
    edited August 2016
    6 months ago I could only spell API, Initially the wikipedia explanation, explained that while I could spell it, it was going to take me a while to learn to API, and a bit more learning to avoid creating "cold API joints" and what all these funny little tubes with wires and colored stripes were for.
    The more I explore, I'm more certain I'm following an the right path through this wilderness. Who knows?, Maybe the world really is round after all. I've seen whats behind, Let's see whats ahead! I'll know more tommorow, follow at your own risk. I wonder what that is, I wonder what it will feel like when I know. See what happens when you look?
    It's easy, just keep us in sight, and you might not get lost, on the journey to API.
    It's probably that a way!
    Let Us Explore!
    73, Jay - NO5J
  • IW7DMH, Enzo
    edited January 2017
    Thank a lot for your explanations, Steve.
    I hope your last two post will be reported in official Flex manuals. I didn't aware of the feature mentioned below until you talked about it.
    ... you can zoom out until the average pixel level reads the same as the slice meter and at that point you are about 500Hz per pixel assuming you have the slice receiver passband set to 500Hz.  This should roughly jive if you take the visible panadapter bandwidth in Hz and divide by about 2000 (this isn't precise for a number of reasons).  Now as you zoom in with the panadapter, you are "looking into the noise floor."
    In this aspect Flex really shines.
    I'll take more time to really figure out what you have written but I have other questions:
    1- as SSDR can access measurement data by itself, could be implemented an adaptive AGC-T function? User could set its preferred audio level (listening in a "only noise" frequency) and SSDR could adapt the threshold to match that setting;
    2- as the listening window of each slice is about +/- 12KHz, could be implemented an additional "slice receiver" only in that window, also in the 6300? I am thinking about a way to use the second slice for skimming and the other one to work, if needed, a split. I know very well I can do it with a 6500 or a 6700, but I am considering the software aspect: as the window data is already sampled for the main slice, is it very hard adding a second audio conversion for the additional slice? (hope I have explained well in my poor english);
    3- last but not least: where can I buy a polo like the one you dressed in this event? https://www.youtube.com/watch?v=LuWaStl0GgI
    Thank a lot for your help
    73' Enzo
    iw7dmh
  • Steve-N5AC
    Steve-N5AC Community Manager admin
    edited February 2017
    We've discussed this in the past.  It's something we are likely to look into in the future when we have some time.
    Actually early in SmartSDR slices were implemented like this -- and two could occupy the same 24kHz bandwidth without anyone really understanding that this was happening.  The issue was that as the slice was moves outside of the window, it then required it's own 24kHz slice of the spectrum.  If you had already used all of them up, we'd be in a quandary: would we stop the slice from moving further?  Would we close it?  Would we generate an error?  Our initial foray into this world was to stop it from moving.  So early in the design you would not be able to move slices further.  This simply confused everyone "my slice is stuck -- it's hit an invisible wall -- why is that wall there?"  In the end, we decided that our customers were likely to not like a feature that says "two, but maybe up to more slices" combined with a slice hitting a wall.  So we pulled this from the system and required each slice to have it's own slice of the spectrum because it seemed that predictability more important.
    Not the exact shirt, but we have all black FlexRadio shirts for sale online now here: http://cart.flexradio.com/FlexRadio-Polo-Shirt--Black_p_934.html
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Hi Enzo,
    Here is an idea to automate the AGC-T setting per your Q&A with Steve below on this topic.
    https://community.flexradio.com/flexradio/topics/option-to-automate-the-agc-t-setting
    The idea has 33 votes so far.  Please add you vote and comments if this is what you are looking for.   It would be nice to see it in V1.5 but suspect is probably is more likely to be considered for V2.x or later.
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    Steve-face_medium
    Steve - N5AC (VP Engineering) replied to this question: Questions about AGC-T algorithm
  • IW7DMH, Enzo
    Actually early in SmartSDR slices were implemented like this ...
    I don't know if it was before or after the 6300 and actually using a 6500 or 6700 it doesn't make sense.
    But using a 6300 it could make. I would stop moving it further but I would try to draw it in a different way so one could be aware of the difference kind of slice. I would also keep it simpler and more ****. Just two controls: volume and bandwidth (I try to picture it below).
    Probably users of 6300 rig would be glad for this.
  • Alan, K2WS
    Alan, K2WS Member ✭✭
    edited February 2015
    Steve, your insight on the inner workings of the DSP really help make sense out of Smartsdr! I hope you guys include a "theory of operation section" in the eManual along with block diagrams. Your discussion on metering has me thinking. Why not allow the user to switch to the AGC+ meter when adjusting a TNF, NR or whatever? How about having the S-meter indicate where the AGC-T is set, in addition to its normal function? How about an indicator in the S-meter that shows when the slice receiver passband width is less than, equal to or greater than the waterfall pixel bin bandwidth? I bet that would clear up confusion about the noise floor of the waterfall being different then the passband noise level in the slice receiver. Any thoughts on this?
    73, Alan K2WS
  • Steve-N5AC
    There's a spectrum of desired quantity of information in the display.  With PowerSDR we tended to throw up anything that might be of use.  With SmartSDR we are working to try to only provide things we believe are necessary and holding back some of the extras.  This is largely because we've been told that too much information can be intimidating.  Also, when we provide information that is not well understood in the past, it has generated large numbers of support calls with folks trying to understand what they are looking at.  For example, we used to allow customers to calibrate the FLEX-5000/3000 series radios using software.  But minor deviations from radio to radio, which are completely normal with analog components, would generate phone calls.
    The discussions surrounding the voltage reading on the FLEX-6000 is a perfect example.  We use this reading internally to determine the state of the master fuse and also to understand if the voltage is below a level tolerable by the internal supplies.  We opted not to show this to customers because of the "man with two voltmeters" problem (which is right?).  DDUtil is reading this voltage out of the radio and showing it to customers.  We have explained where this comes from and that there is, necessarily, some drop in the voltage.  There are regularly discussions about why this voltage is different, why our measurements might have the wrong calibration (they don't, it's just drop internally), etc.
    For myself, I would prefer that the dashboard of my Suburban look like an F-16.  I'm an instrumentation ****.  We have metering that measures about 10 voltages and something under that in current measurements.  We use these internally for diagnostics and I'd probably show them all in a display ;-) The more information, the better.  I have learned by talking to others that everyone does not share this view of the world and that having a lot of data that is not immediately relevant is not useful for most folks.  So this is the overall approach that we have taken.
    Now that I've rambled about how we got here, we could come up with displays/indicators that show the things you are talking about.  I especially like the dB differential in the slice and panadapter metering.  I would recommend adding it to the Idea section and encouraging folks to upvote it.  No doubt that we will return to the list periodically and grab things from there to go implement that have wide interest.
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    So you mean you'd throw a fit if I asked if 13.7V supply is okay, hi hi?
    Rather than *more* instrumentation, I would like the readability/usability issues addressed first. Al (NN4ZZ) has produced some excellent mockups that would transform SSDR's power meter for example.
    Are there any plans to modify SSDR's interface or to allow more customisation? For example, I'd replace the graphic equaliser with the DAX control panel in a blink of an eye. I use the latter far more and it is not as accessible as the former.
