swap my 6500 for a 6700 or a second 6500 ?
Hi  already own a 6500 for near 6 Mont but as my interest was in VHF and up
i run multiple Transverter  so on my 6500 i only able to monitor one band at the time
so i look for a 6700 but honestly price was  double of a 6500 for add a extra ADC Chip(SCU)
may it better to simply buy another  6500 and have a extra TX  ( full duplex ) and spare radio  ?
i assume that on a 6700 if you tune to 144 you cannot monitor HF on the same SCU ,since harmonic filter  ?   like  144 + 432 > 28 on  SCU #1 and 1296 > 28 on SCU #2  so 3 band  ;-)
alos since smartSDR handel only 1 radio  did for V2.0  it was 200$ x 2 ?
so what you opinion
73  Marc L.  VE2OLM
Welcome!
  • Member ✭✭
    edited April 2017
    Marc, I think the right answer is not replace but add too
  • Member ✭✭
    edited February 2015
    Can you run two radios at the same time on the same computer? Would diversity then work across both transceivers?
  • Member ✭✭
    edited April 2015
    Thom, sorry i mean add too......6700
  • Member ✭✭✭
    edited November 2016
    I think the issue might be software. I am not sure you can run 2 instances of SmartSDR on the same computer. You might need separate computers for 2x6500 versus one computer for 1x6700. I could be wrong.... but if that is the case, you might want to look into the cost of having two computers and separate monitors for each... etc...
    Last time I tried to run a 6300 and a 6500 on the same PC at the same time I couldn't.
  • Member ✭✭
    edited March 2017
    Tim has said that SmartSDR does not support multiple instances on the same computer at this time.
  • Member ✭✭
    edited May 2017
    I recommend upgrading to 6700 for diversity RX.
  • Member ✭✭✭
    edited February 2017
    Right now we have simple diversity but only on the 6700.  Full diversity requires two (or more?) in phase IQ streams.  This means a 6700 with two separated antennae (GPSDO option not required) or two 6000 series RX anywhere in the world (GSPDO is required).
    So now a 6700; sometime later GPSDO on two members of the 6000 series.
    I failed to find the FRS reference in this community, at least a year ago.
    73  Stan
  • Member ✭✭
    edited July 2015
    Hi  diversity was probably useless for EME  antenna point to sky were noise was very low
    and not sure about it for terrestrial weak signal on VHF and above ?
    i think that this is more for the noisy HF ?
    second PC was not a big issue i already have 2 PC on 3 monitor
    youk knot whit SamrtSDR , pstrotator ,WSJTX , web chat for sked ,QRZ.com
    you need quickly more Display/PC ;-)
    hope that in V2.0  or later it handel multiple radio ,that will become plus value when remote  will work  ,whit local radio and a remote one
    and wly not have cluster of remote available radio ;-))
