Laptop for wireless use with 1.4 on 6300.
Alan Nusso, N4BV
I am considering a Toshiba laptop running an I5 Intel processor at 1.7 Ghz with 8G of memory. It has HD Graphics with shared memory. I would appreciate some input on this laptop's suitability for my 6300. It is a Toshiba. It will be running Windows7 Professional 64 bit which I prefer. I plan on running wireless.
I would look for a gamer laptop as the specs are usually good.
If your going to multiple app running also need the umph.
I run SmartSDR out of a VMWare image on a MacBook Pro, and your hardware specs run circles around that. I'd reckon you'd be fine.0
I had a chance to try the alpha version of 1.4 . I did lan remote using a hp notebook low end with I5 processor . It did ok but as someone said if you run anything else with it such as a logging program, ddutil, or fldigi I am afraid you will have issues with smart sdr. If you have it already no loss but if buying a new machine I would go for a faster processor and plenty of memory.0
You should not have any problem apart from one issue. I have a 6300 and it runs just fine on the integrated Intel HD 3000 with all options maxed out. The issue is that the sharing of memory does funny things with a FlexControl, and that is the *only* reason why I use the dedicated Nvidia 630M that this laptop (Acer Aspire) also has. SSDR is not even beginning to tax my laptop and v1.4 will be even better on resources.
Thanks which model do you have?0
Hi Alan, here are the spec's on my my MacBook Pro running Windose 8.1 Pro. Smart SDR runs just fine on it.
73, Dan KM6CQModel Name: MacBook Pro
Model Identifier: MacBookPro9,2
Processor Name: Intel Core i5
Processor Speed: 2.5 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 3 MB
Memory: 16 GB
Boot ROM Version: MBP91.00D3.B08
SMC Version (system): 2.2f44
Hardware UUID: 8A0E2408-7D95-5C14-B3C4-3DDA62127805
Sudden Motion Sensor:
State: Enabled
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 942 Genius Products
- 346 Tuner Genius XL
