Flex6500 20 meters only processor, dexp, eq are half lit, unable to change settings. Have reloaded s
6500,  20 meters only ssb processor, dexp, eq , half lit unable to change the three controls. all normal on other bands. Have rebooted, and downloaded software.Thanks
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    1) Do you accidentally have DigiU or DigiL enabled instead of SSB?
    2) Try a persistence reset - First backup your total profiles, then turn the rig off.  Restart it by holding the center "OK" button in while activating the power switch.  This will reset all of the persistence parameters.  Then you can import your profiles again.  See if this helps.
    Ken - NM9P
  • Jay Nation
    Jay Nation Member ✭✭
    edited May 2019
    Find the DAX button on the P/CW tab. the DAX button disables those features.
    Either that or what Ken said.
    Jay - NO5J
  • Joe DiMare
    Joe DiMare Member
    edited February 2015
    Jay
    Thank you very much, the dax button was on by mistake. Again thank you.
    Regards,
    Joe
  • Joe DiMare
    Joe DiMare Member
    Thank you Ken very much, had the digi on went back to ssb all is fine.
  • Jay Nation
    edited May 2019
    No thanks neccesary, as Emily used to say, "It's always something."
