Flex6500 20 meters only processor, dexp, eq are half lit, unable to change settings. Have reloaded s
Joe DiMare
6500, 20 meters only ssb processor, dexp, eq , half lit unable to change the three controls. all normal on other bands. Have rebooted, and downloaded software.Thanks
1) Do you accidentally have DigiU or DigiL enabled instead of SSB?
2) Try a persistence reset - First backup your total profiles, then turn the rig off. Restart it by holding the center "OK" button in while activating the power switch. This will reset all of the persistence parameters. Then you can import your profiles again. See if this helps.
Ken - NM9P
Find the DAX button on the P/CW tab. the DAX button disables those features.
Either that or what Ken said.
Jay - NO5J0 -
Jay
Thank you very much, the dax button was on by mistake. Again thank you.
Regards,
Joe0 -
Thank you Ken very much, had the digi on went back to ssb all is fine.0
No thanks neccesary, as Emily used to say, "It's always something."0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
