Can an external autotuner connected to a flex 3000?
Pierre Martel
I have a flex 3000 And I have an AT-200 pro ldg autotuner. On some band when I do SSB the autotuner will start to autotune cause I have to program it as autotune on RF cause I do lots of remote control of my rig. Now it is not fun to have your autotuner go crazy switching while talking to a friend!
Now if the flex 3000 could control the ldg tuner, it would tell it to tune when the tune fonction is on, and not on rf sensing..
So is there a way to do so?
Why are you using a 200 watt tuner with a Flex-3000, since it has it's own tuner built in?0
I also use an LDG at-100PROII auto tuner with my flex-6500 and sometime a z-11proII. I have no issues with them at any time. There are setting in the tuner to set that will prevent it from doing what you describe.
As for why use an external tuner, Both my 3000 and 6500 internal tuners did not have enough range to tune a non-resonant multi-band antenna.0 -
For the simple reason the ldg will tune much worst antanna then the internal flex tuner.0
Well it looks like I cant RTFM properly.. never found such thing in it.. care to point me in the right direction? ;-)
In my manual on page 11 on auto threshold.
The other question is whether or not the LDG tuner has means to accept extendable control commands. Were I at home and not on travel sans computer, I would have researched that before answering. If it does, you may wish to explore using DDUTIL and the macro commands available via PSDR. Ted0
ddutil? never seen this, care to explain?0
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 141 Contesting
- 985 Third-Party Software
