Antenna noise on my 6300
Andy M1DRK
All this is antenna based interference.
_inline.jpg)
_inline.jpg)
You have now become aware of how noisy the world has become.
Everything from the drive electronics on a variable-speed furnace fan to the circuits built into LED light bulbs is making noise. The harmonics of the pulse-width modulated square waves in these things make those "humps".
Do you remember learning somewhere along the way that a square wave is made up of a fundamental sine wave and an infinite number of its odd-order harmonics?
Well, now you know what that looks like on a spectrum analyzer.
Look to your home for a switching power supply or something like that. WALL WART ... In my case it was the power supply for and external hard drive see attached picture. I turned off breakers one by one until the noise went away... This went all the way up into 10 meters. See Dr. Howard S. Whites paper on how to build a quite station https://community.flexradio.com/flexradio/topics/how-to-build-a-quiet-station
Hope this helps...
Regards & 73's
Dan --- KC4GO
This was my mess !!!
I get a pattern very similar to that from the under cabinet halogen lights in the kitchen. They are powered by an old wall-wart power supply. It wipes out 160-10 meters. I haven't had the opportunity to replace it yet.0
Agree with Bob, this looks like the same i observe on a " Maytag Neptune washing machine RFI " (Google it). I've tried grounding the wash machine case to the copper pipes and wrapped the AC cord 15 times thru a huge 31-mix ferrite to no effect whatsoever. I believe one has to attack it at the source itself, the motor leads.
As mentioned, it's a noisy world now..
In the middle of the night around here, the RFI is nonexistent except for a few spurs that I can live with.
I find it's easier to track down RFI problems at 2:00AM to 5:00AM or so when the outside sources are generally off. Also that let me bag K1N this morning on RTTY!
Good Luck +
73's
k3Tim
So sorry you're now "enjoying" all the radio spectrum can offer! I spent over a year obsessively tracking down noise before I called it quits and realized there was some stuff I couldn't clean up (other people's washing machines, pool pumps, plasma TV, etc. KY6LA has a great presentation on cleaning up your own house. A recounting of my experiences is on my QRZ page. There is A LOT you can do. I also found the MFJ noise canceller (phase device) helps with some sources. I think it was Tim who first told me what I call the Flex Paradox - the best and worst thing about a Flex radio is the spectrum display coupled with that awesome receiver. Now you can obsess about noise you never knew about before! And wow, what a difference when you succeed. GOOD LUCK!1
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 941 Genius Products
- 345 Tuner Genius XL
