No Audio on Flex 6300 Smart SDR Install
Chris in CR
Chris in CR Member
edited January 2017 in FLEX-6000 Signature Series
Hi Everyone,
Just tested and passed both my Tech and General exams this past Saturday at the Tropical Hamboree in Miami.
I made a clean install of Windows 8.1 on my iMac using Boot Camp and I have full operation of audio controls when watching YouTube or a video file, etc.
However, with the install of SmartSDR for Windows, I get all access to my radio and the controls, but none of the DAX options that installed will produce audio through the Mac.
I can hear audio when I connect speakers to rear panel on radio and headphones through front panel.
But no audio via DAX Audio as listed in Playback devices.  I've clicked through each one ans selected 'Test.'  The only device that produces sound is the Mac speaker.
I've selected each, one at a time as Default Device with the same result.
SmartSDR v1.3.8
Any ideas?
Thanks in advance,
Chris
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited January 2017
    Congratulations!
    Have you turn ON the Audio Stream? The number 1 in blue means that it is on and the red TX means that I can also use the DAX to transmit.
    Also make sure you have selected the Channel on the Slice:
    You probably have already turned those ON but I wanted to make sure.
    Good luck,
    Salvador
  • Chris in CR
    Chris in CR Member
    edited February 2015
    Thanks for the quick reply.
    I checked those settings and confirmed that in the DAX Control Panel audio stream 1 is selected and highlighted in blue.
    Also on the slice flag, under the DAX tab, I have selected Channel 1.
    In my computer's Playback Devices options I can see the green bars reflecting that audio is being received into that channel: DAX RESERVED AUDIO RX 1, but nothing audible makes it out of computer speakers.
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
    Select Recording Device (Not Playback)
    You should listen to DAX AUDIO RX1
    Double Click on it and Select Listen to this Device
  • Chris in CR
    Chris in CR Member
    You sir, deserve a ****.  Thank you!
  • Rob N4GA
    Rob N4GA Member ✭✭
    Congrats on obtaining your license Chris in CR!
    And getting the audio to come through your PC.
    This forum is great!
  • Chris in CR
    Chris in CR Member
    Thanks, Rob!
    Will be a big adjustment for me. This is definitely not a plug and play hobby.
    But the forum already pushed me in the right direction. They are good!
