logger with smartsdr
Gene - K3GC
I have read in the community that there are some loggers that can recognize more than on slice but I can't seem to find those posts.
in any case, I would like to see a list of those loggers that support more than one slice. I use logic 9 which will only recognize one - maybe I will have to change
Be sure to check out the new N1MM Logger+. While it is still a work in progress, it does talk to Slice A and Slice B rather well.0
DX4WIN only works correctly if you have 2 slices open. Unfortunately, I haven't had enough time yet working with it and SSDR to tell you much more. It did log a station I worked split correctly. Maybe someone else can give you more info on it if you're interested.
73, Duane
DXLab talks to two slices just fine.
Jon...kf2e
MacLoggerDX works smoothly with the 6000 series and two "VFOs." Beyond two, I'm not sure you will find much support - yet.
let me know if you fine one that will do more than 2
Log4OM is working on an update to support multiple slices. Probably a few months away. They are looking at the api for the interface. Regards, Al / NN4ZZ0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
