Help Needed! Can't get software to launch!
Steve Parker
Hooked up, software installed, sees radio, but won't connect? I uninstalled and reinstalled the software twice, still won't launch! I do better talking..... 859-582-9623 if you don't mind. Thanks.... NZ4Z
You might try rebooting your router. Although you don't need to use port forwarding on your router it does assign the radio an I/P address on my LAN. On my router it registers as 192.168.1.16 using a Linksys router. When I turn off the radio that I/P address disappears.
When I scan my LAN the name comes up as Texas Instruments c6a816x-evm.
Unless the router "sees" the radio it will not work.
Jim, K6QE
Try starting with the radio plugged right into your PC. No switches, routers, etc. Reboot both (PC first) and see if there's a link. That will prove the NIC, cable, and Flex.
Steve,
Open CMD window and do ipconfig.
1. What is the IP of your workstation
2. Compare that to the IP that is showing in SmartSDR.
When I first brought my radio it could not find the DHCP so it defaults to an IP of 169.x.x.x which means it is not getting the correct IP from your network.
Also try entering PING (IP address displayed by SmartSDR)
This will confirm you have a route to the radio.
Lee
To bad a guy has to be a network wiz to get it working....
Just try removing power from your router wait a few seconds and turn it back on.0
Thanks everyone......up and running0
Steve what was the resolution ?0
He suddenly became a Network Wiz and solved it! hihi
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
