Transmitter Inhibit of Transverter - 6300
I have a Flex-6300 and am using the Transverter Port as a receiver input for my Pixel Magnetic Loop, which is a receive only antenna. Transmitting even the low power available at the Inverter Antenna Port would destroy the Pixel's preamplifier.
I understand how to inhibit transmit globally, but since I need to both transmit on a separate antenna, as well as receive through the XVTR port, I was hoping to find a software methodology of disabling transmission through the XVTR connection.
Because I am getting older, my fear is that I will miss setting the antenna selectors correctly just once and destroy a $200 potted preamp. Since the settings are changeable for each band, the probability of such an accident is much higher.
My suggestion is to add a software switch which can universally prevent transmission through the XVTR port on the 6300 at least; recognizing this may not be necessary with the 6500 and 6700.
It's not my $200 at risk, but I think its doubtful that the 10 milliwatts that is available from the6300 Xvtr port would damage the Pixel amplifier output. ( I do have a Pixel loop and have that much coupled from my TX antenna into the loop. ) Just my 2 cents. ( your $200 )
Al, K0VM
Just to be safe, I would install a circulator that would allow RF from the antenna to the port, but direct any output RF to a dummy load.1
Having killed my Pixel by transmitting into it, I can tell you it is repairable. It took me a few weeks, but I did get it back operational. Neither the control box or the antenna amplifier are potted. The sad thing is that Pixel will not release any schematics nor help should you do so. They make a great product however, their only solution is to sell you a complete new antenna if you **** it up.
I would highly recommend you install a proper T/R switch that will ensure that the hardware control takes it out of line 100% of the time. They aren't that complicated or you can buy a very well made RTR-1 from DX Engineering that works wonderfully.
Mike va3mw0 -
Michael could you clarify. Did you have the Pixel on one of the main TX ports of your radio (was it a Flex?) rather than aux ports designed for RX antenna inputs. Or was it a case of the correct port being used fby the Pixel antenna but not using a front end saver device when the antenna was being used in close proximity to your full power TX antenna.0
Transmit inhibit on the XVTR port would be a very welcome addition. My guess is that is low on their long list of changes but seems like a relatively easy change.0
It was on my TS480 remote base and it was my fault. Nothing to do with a Flex radio.0
I have added this request to the feature enhancement database for consideration in a future version of SmartSDR.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
