N1MM+ Voice Keyer Configuration for Flex-6500
Gary Robertson - KY5R
In the Community, I have seen several conversations about using N1MM+ Voice Keyer capabilities with the Flex-6000 radios. Does anyone have a step-by-step description for properly configuring N1MM+ so that I can use its Voice Keyer with my Flex-6500? Tips on how to record various .wav files to playback when I hit an N1MM+ function key would also be helpful. Possibly, N9IO or W9IE can help me but I will accept assistance from anyone.
2
I've been trying to do this too. I thought there might be a YouTube video or something that outlines it, but I could not find one.
If I get it working, I'll make a video thoughI have a 6300 so it should be pretty similar.
Thanks Kevin. Any assistance would be greatly appreciated.0
Ok.. I ended up making a PDF, I'm too stopped up to record anything
http://www.highorbit.com/higho/Configuring_n1mm_for_Voice_Call.pdf
Hopefully I didn't miss any steps. If you end up with any trouble please let me know and I'll see if I can still help.
Thanks Kevin. I made the changes you provided in the PDF. I think it is going to work but currently N1MM+ can't find my pre-recorded callsign in the noted documents file when I press F1. I will do some more research and figure it out. I truely appreciate your help.0
Bump! Link is broken, can I find it somewhere else?
I would love to see the quite too, Kevin, please, can you give us a new link?0
You didn't here it hear, but when SmartSDR v1.6 is released, I think you will find a nifty solution to the N1MM voice keyer issue.2
Ha... I didn't realize that was my PDF... Not sure what I did with it though, sorry. Can't wait to see the nifty solution though.0
Tease us some more! Oh!. It would be nice to have it for the weekend CQWW SSB contest! . I would love to be able to record a tutorial on the subject...if I had time to learn it first..... (;p)0
Found it.. here's a google doc link:
https://drive.google.com/a/workflow-automation.com/file/d/0BzV9t9lMVT6dRW1KTTZKbHUwVms/view?usp=shar...
Tim, I didn't hear it here but any word yet on a projected release date for SmartSDR v1.6? Also, while whoever is testing the API with N1MM+, could they let us know if it will work with the N3FJP software suite too? If whoever does not have the suite, it can be obtained on a trial basis for free from the http://n3fjp.com website. Also, from this posting (https://community.flexradio.com/flexradio/topics/is_there_a_way_to_get_a_voice_keyer_running_through...), I plan to contact Scott Davis, N3FJP, about making the necessary changes (if any) to his programs for interfacing the voice and CW keyers to the FLEX 6000 series radios. Is there somebody at FLEX Radio that I could put Scott in touch with to discuss making his programs work like N1MM+ with the FLEX 6000 series radios? Thanks in advance! 73, Dave Hamm, K4EET0
- 317 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
