Can anyone post their settings for the DEMI 2M75LPDA ?
Roy Laufer
Can anyone who already owns a DEMI 2M75LPDA for 2 Meter use with the 6700 post their working settings?
RF Freq. and IF Freq. are both understood to be 144.000 MHz. Max Power seems to accept nothing higher than 8.0 dBm, what is the recommended setting?
What about RX Gain?
Thanks!
Roy, AC2GS
Hi Roy,
I set the RX-Gain to +20dB. I use the max RF power. Look at the bar-graph on the LPDA to check the drive level. In Setup-XVTR You can compensate the S-meter for S9= -93 dBm. Good luck.
- 633 The Flea Market
- 129 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
