error when trying to open a DAX i/Q stream
ole puschl
when trying to open af dax i/q stream I am getting af sign with the text:
" an error has occured when trying to open a dax driver. Make sure no other applications are using RESERVED DAX devices.
If the problem persist please trye reinstalling Smart SDR og consult FlæexRadeio suppåort via online community or helpdesk"
I have tryed to uninstall and reinstall the SmartSDR without any help
Go to your Sound Properties, usually in the lower right corner of the Windows Task Bar at the bottom of screen, right click on the little speaker.. Your Windows Default sounds should not be on any of the DAX audio or I/Q DAX drivers, real or reserve.. Windows default sounds (the Green check) needs to be on any other device, but usually Speakers and Microphone connected to your sound card (or a blank plug to make it active as Windows will disable your sound card if nothing is plugged into it) .. This is way that error is trying to tell you. :-)0
thanks for your promt ansv.
I am not sure it solves my problem.
Here is what my screen look likes
ok.got it working now.
tu help
73 de
oz1op /ole püschl
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
